[mapguide-users] RE: IIS Configuration of Mapguide OS - testing web
server extensions fails
padmini godavarthi
godavarthi.padmini at gmail.com
Fri Jan 22 01:19:21 EST 2010
Hi Kenneth,
Thanks for your reply .
I followed the guidelines given in ul. the problem is solved.
Now Actually my poblem is that while running on show in browser the
exceptions comes that
System.Security.Permissions.SecurityPermission
I have seen the same error posted by somebody and replied by you
http://n2.nabble.com/security-exception-webconfig-ini-td1813100.html#a1813100
i think that the problem might be with IIS (Application Pools).iam unaware
of that.so iam unable to find the problem as well as solution.
In my system
IIS
Application Pool
|___MapguideApplication Pool
Default Web site
SharePoint -80
|---Mapadmin
MapAgent
MapviewerAjax
is there
so plz giv me guidence so that it would be helpful to me...
Note:-Iam logged as a system Administrator
View this message in context: http://n2.nabble.com/IIS-Configuration-of-Mapguide-OS-testing-web-server-extensions-fails-tp1804217p4438559.html
