[mapguide-users] RHEL 5.4 and mapguide problem
Randall Read
randallread at yahoo.com.au
Tue Jan 26 20:18:22 EST 2010
I have installed mapguideopensource (2.0.2) on RHEL 5.4, and mapguide compiles and installs successfully, (along with the webserverextensions) but I now have a problem with Tomcat crashing. It is related to the mapguide libraries, $PATH/mapguideopensource/webserverextensions/lib and $PATH/mapguideopensource/lib, as defined in the tomcat startup (catalina.sh) using LD_LIBRARY_PATH.
As soon as I try to access a page like /mapviewerjava/ajaxviewer.jsp, which uses these libraries, tomcat crashes, and it spits out the below error message.
I've searched high and low for a couple of weeks trying to find any resolution to this problem, and have tried almost anything suggested, but no-one seems to have the same problem. There is one open ticket for Centos in which mapguide crashes with a seemingly similar problem, but mapguide (running as daemon) does not crash on my system.
I thought I'd better ask here before I try to open a ticket about it. Any help would be appreciated.
hs_err_pid8058.log
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0xaa3dbd64, pid=8058, tid=2867907472
# JRE version: 6.0_17-b04
# Java VM: Java HotSpot(TM) Client VM (14.3-b01 mixed mode linux-x86 )
# Problematic frame:
# C [libMgMapGuideCommon.so.7+0xc5d64] _ZN6MgSite12AuthenticateEP17MgUserInformationP10MgSiteInfoP18MgStringCollectionbb+0x64
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0xab037800): JavaThread "TP-Processor3" daemon [_thread_in_native, id=8071, stack(0xaaebc000,0xaaf0d000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x0000000c
Registers:
EAX=0x0000000c, EBX=0xaa491948, ECX=0xaa491948, EDX=0xaa48e7f8
ESP=0xaaf0b730, EBP=0xaaf0b808, ESI=0x00000000, EDI=0x00000000
EIP=0xaa3dbd64, CR2=0x0000000c, EFLAGS=0x00010206
Top of Stack: (sp=0xaaf0b730)
0xaaf0b730: aaf0b7a4 aa3374ec aa32d4fc 00000001
0xaaf0b740: 05114a1d 00000000 00000000 aaf0b844
0xaaf0b750: 005a4a97 aa32d4fc aaf0b828 085aa334
0xaaf0b760: 00000005 00000000 aaf0b7a4 00000000
0xaaf0b770: 00000001 08509280 085ebd20 aa3160e4
0xaaf0b780: 00009280 0000000c aaf0b7a8 aaf0b8c4
0xaaf0b790: eb628dc7 00000000 00000000 085ebd20
0xaaf0b7a0: eb628dc6 aa48e7f8 00000000 00000000
Instructions: (pc=0xaa3dbd64)
0xaa3dbd54: c0 0f 84 6f 01 00 00 8d 47 0c 89 85 7c ff ff ff
0xaa3dbd64: 8b 47 0c 85 c0 0f 85 59 02 00 00 e8 a0 81 fa ff
Stack: [0xaaebc000,0xaaf0d000], sp=0xaaf0b730, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libMgMapGuideCommon.so.7+0xc6e31] _ZN6MgSite4OpenEP17MgUserInformationb+0x51
C [libMgMapGuideCommon.so.7+0xc7469] _ZN6MgSite4OpenEP17MgUserInformation+0x39
C [libMapGuideJavaApi.so.7.0.0+0xade31] Java_org_osgeo_mapguide_MapGuideJavaApiJNI_MgSite_1Open_1_1SWIG_10+0x41
j org.osgeo.mapguide.MapGuideJavaApiJNI.MgSite_Open__SWIG_0(JJ)V+0
j org.osgeo.mapguide.MgSite.Open(Lorg/osgeo/mapguide/MgUserInformation;)V+8
j org.apache.jsp.javaviewersample.ajaxviewersample_jsp._jspService(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+236
j org.apache.jasper.runtime.HttpJspBase.service(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+3
j javax.servlet.http.HttpServlet.service(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+30
j org.apache.jasper.servlet.JspServletWrapper.service(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Z)V+315
j org.apache.jasper.servlet.JspServlet.serviceJspFile(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljava/lang/String;Ljava/lang/Throwable;Z)V+193
j org.apache.jasper.servlet.JspServlet.service(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+436
j org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+376
j org.apache.catalina.core.ApplicationFilterChain.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+101
j org.apache.catalina.core.StandardWrapperValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+804
j org.apache.catalina.core.StandardContextValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+365
j org.apache.catalina.core.StandardHostValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+64
j org.apache.catalina.valves.ErrorReportValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+6
j org.apache.catalina.core.StandardEngineValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+42
j org.apache.catalina.connector.CoyoteAdapter.service(Lorg/apache/coyote/Request;Lorg/apache/coyote/Response;)V+157
j org.apache.jk.server.JkCoyoteHandler.invoke(Lorg/apache/jk/core/Msg;Lorg/apache/jk/core/MsgContext;)I+123
j org.apache.jk.common.HandlerRequest.invoke(Lorg/apache/jk/core/Msg;Lorg/apache/jk/core/MsgContext;)I+374
j org.apache.jk.common.ChannelSocket.invoke(Lorg/apache/jk/core/Msg;Lorg/apache/jk/core/MsgContext;)I+191
j org.apache.jk.common.ChannelSocket.processConnection(Lorg/apache/jk/core/MsgContext;)V+105
j org.apache.jk.common.ChannelSocket$SocketConnection.runIt([Ljava/lang/Object;)V+8
j org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run()V+167
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
V [libjvm.so+0x213740]
V [libjvm.so+0x327158]
V [libjvm.so+0x212f47]
V [libjvm.so+0x212ffa]
V [libjvm.so+0x290315]
V [libjvm.so+0x3ca73e]
V [libjvm.so+0x3285fe]
C [libpthread.so.0+0x55ab]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0xab0d1800 JavaThread "TP-Monitor" daemon [_thread_blocked, id=8073, stack(0xaae1a000,0xaae6b000)]
0xab0cac00 JavaThread "TP-Processor4" daemon [_thread_in_native, id=8072, stack(0xaae6b000,0xaaebc000)]
=>0xab037800 JavaThread "TP-Processor3" daemon [_thread_in_native, id=8071, stack(0xaaebc000,0xaaf0d000)]
0xab04ac00 JavaThread "TP-Processor2" daemon [_thread_blocked, id=8070, stack(0xaaf0d000,0xaaf5e000)]
0xab039800 JavaThread "TP-Processor1" daemon [_thread_blocked, id=8069, stack(0xaaf5e000,0xaafaf000)]
0xab09a400 JavaThread "http-8080-Acceptor-0" daemon [_thread_in_native, id=8068, stack(0xaafaf000,0xab000000)]
0xab0b1c00 JavaThread "ContainerBackgroundProcessor[StandardEngine[Catalina]]" daemon [_thread_blocked, id=8067, stack(0xab12c000,0xab17d000)]
0xab311000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=8065, stack(0xab22e000,0xab27f000)]
0xab30f400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=8064, stack(0xab27f000,0xab300000)]
0xab30dc00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=8063, stack(0xab429000,0xab47a000)]
0x08558400 JavaThread "Finalizer" daemon [_thread_blocked, id=8062, stack(0xab67a000,0xab6cb000)]
0x08556c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=8061, stack(0xab6cb000,0xab71c000)]
0x0850b000 JavaThread "main" [_thread_in_native, id=8059, stack(0xb76d0000,0xb7721000)]
Other Threads:
0x08552c00 VMThread [stack: 0xab71c000,0xab79d000] [id=8060]
0xab312c00 WatcherThread [stack: 0xab1ad000,0xab22e000] [id=8066]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 960K, used 169K [0xab9f0000, 0xabaf0000, 0xabed0000)
eden space 896K, 15% used [0xab9f0000, 0xaba12938, 0xabad0000)
from space 64K, 49% used [0xabad0000, 0xabad7db0, 0xabae0000)
to space 64K, 0% used [0xabae0000, 0xabae0000, 0xabaf0000)
tenured generation total 4096K, used 4008K [0xabed0000, 0xac2d0000, 0xaf9f0000)
the space 4096K, 97% used [0xabed0000, 0xac2ba0c0, 0xac2ba200, 0xac2d0000)
compacting perm gen total 12288K, used 12278K [0xaf9f0000, 0xb05f0000, 0xb39f0000)
the space 12288K, 99% used [0xaf9f0000, 0xb05ed870, 0xb05eda00, 0xb05f0000)
No shared spaces configured.
Dynamic libraries:
00101000-0010c000 r-xp 00000000 fd:00 426894 /lib/libgcc_s-4.1.2-20080825.so.1
0010c000-0010d000 rwxp 0000a000 fd:00 426894 /lib/libgcc_s-4.1.2-20080825.so.1
001ee000-00281000 r-xp 00000000 fd:02 855011 /usr/lib/libkrb5.so.3.3
00281000-00284000 rwxp 00092000 fd:02 855011 /usr/lib/libkrb5.so.3.3
00286000-0028d000 r-xp 00000000 fd:02 67078 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/jli/libjli.so
0028d000-0028f000 rwxp 00006000 fd:02 67078 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/jli/libjli.so
0029d000-0030c000 r-xp 00000000 fd:02 919551 /usr/lib/libodbc.so.1.0.0
0030c000-00310000 rwxp 0006e000 fd:02 919551 /usr/lib/libodbc.so.1.0.0
00310000-00311000 rwxp 00310000 00:00 0
00543000-00568000 r-xp 00000000 fd:02 854832 /usr/lib/libpng12.so.0.10.0
00568000-00569000 rwxp 00024000 fd:02 854832 /usr/lib/libpng12.so.0.10.0
0059b000-005b5000 r-xp 00000000 fd:00 426001 /lib/ld-2.5.so
005b5000-005b6000 r-xp 00019000 fd:00 426001 /lib/ld-2.5.so
005b6000-005b7000 rwxp 0001a000 fd:00 426001 /lib/ld-2.5.so
005b9000-006f8000 r-xp 00000000 fd:00 426008 /lib/libc-2.5.so
006f8000-006f9000 --xp 0013f000 fd:00 426008 /lib/libc-2.5.so
006f9000-006fb000 r-xp 0013f000 fd:00 426008 /lib/libc-2.5.so
006fb000-006fc000 rwxp 00141000 fd:00 426008 /lib/libc-2.5.so
006fc000-006ff000 rwxp 006fc000 00:00 0
00701000-00703000 r-xp 00000000 fd:00 426022 /lib/libdl-2.5.so
00703000-00704000 r-xp 00001000 fd:00 426022 /lib/libdl-2.5.so
00704000-00705000 rwxp 00002000 fd:00 426022 /lib/libdl-2.5.so
00707000-0071a000 r-xp 00000000 fd:00 426024 /lib/libpthread-2.5.so
0071a000-0071b000 r-xp 00013000 fd:00 426024 /lib/libpthread-2.5.so
0071b000-0071c000 rwxp 00014000 fd:00 426024 /lib/libpthread-2.5.so
0071c000-0071e000 rwxp 0071c000 00:00 0
00720000-00745000 r-xp 00000000 fd:00 426016 /lib/libm-2.5.so
00745000-00746000 r-xp 00024000 fd:00 426016 /lib/libm-2.5.so
00746000-00747000 rwxp 00025000 fd:00 426016 /lib/libm-2.5.so
00749000-00750000 r-xp 00000000 fd:00 426032 /lib/librt-2.5.so
00750000-00751000 r-xp 00006000 fd:00 426032 /lib/librt-2.5.so
00751000-00752000 rwxp 00007000 fd:00 426032 /lib/librt-2.5.so
00754000-0076a000 r-xp 00000000 fd:00 426040 /lib/libselinux.so.1
0076a000-0076c000 rwxp 00015000 fd:00 426040 /lib/libselinux.so.1
0076e000-007a9000 r-xp 00000000 fd:00 426036 /lib/libsepol.so.1
007a9000-007aa000 rwxp 0003b000 fd:00 426036 /lib/libsepol.so.1
007aa000-007b4000 rwxp 007aa000 00:00 0
007b6000-007c8000 r-xp 00000000 fd:02 854416 /usr/lib/libz.so.1.2.3
007c8000-007c9000 rwxp 00011000 fd:02 854416 /usr/lib/libz.so.1.2.3
007cb000-00806000 r-xp 00000000 fd:02 855158 /usr/lib/libcurl.so.3.0.0
00806000-00807000 rwxp 0003b000 fd:02 855158 /usr/lib/libcurl.so.3.0.0
00970000-0099d000 r-xp 00000000 fd:02 855015 /usr/lib/libgssapi_krb5.so.2.2
0099d000-0099e000 rwxp 0002d000 fd:02 855015 /usr/lib/libgssapi_krb5.so.2.2
009fa000-00a3d000 r-xp 00000000 fd:00 427604 /lib/libssl.so.0.9.8e
00a3d000-00a41000 rwxp 00042000 fd:00 427604 /lib/libssl.so.0.9.8e
00a96000-00aa9000 r-xp 00000000 fd:00 427598 /lib/libnsl-2.5.so
00aa9000-00aaa000 r-xp 00012000 fd:00 427598 /lib/libnsl-2.5.so
00aaa000-00aab000 rwxp 00013000 fd:00 427598 /lib/libnsl-2.5.so
00aab000-00aad000 rwxp 00aab000 00:00 0
00aaf000-00bd9000 r-xp 00000000 fd:00 426206 /lib/libcrypto.so.0.9.8e
00bd9000-00bec000 rwxp 00129000 fd:00 426206 /lib/libcrypto.so.0.9.8e
00bec000-00bf0000 rwxp 00bec000 00:00 0
00bf2000-00bf4000 r-xp 00000000 fd:00 427603 /lib/libcom_err.so.2.1
00bf4000-00bf5000 rwxp 00001000 fd:00 427603 /lib/libcom_err.so.2.1
00c23000-00c32000 r-xp 00000000 fd:00 427602 /lib/libresolv-2.5.so
00c32000-00c33000 r-xp 0000e000 fd:00 427602 /lib/libresolv-2.5.so
00c33000-00c34000 rwxp 0000f000 fd:00 427602 /lib/libresolv-2.5.so
00c34000-00c36000 rwxp 00c34000 00:00 0
00d44000-00d65000 r-xp 00000000 fd:02 917771 /usr/lib/libjpeg.so.62.0.0
00d65000-00d66000 rwxp 00020000 fd:02 917771 /usr/lib/libjpeg.so.62.0.0
00d7a000-00d7c000 r-xp 00000000 fd:00 427601 /lib/libkeyutils-1.2.so
00d7c000-00d7d000 rwxp 00001000 fd:00 427601 /lib/libkeyutils-1.2.so
00d7f000-00d87000 r-xp 00000000 fd:02 854925 /usr/lib/libkrb5support.so.0.1
00d87000-00d88000 rwxp 00007000 fd:02 854925 /usr/lib/libkrb5support.so.0.1
00d8a000-00daf000 r-xp 00000000 fd:02 855009 /usr/lib/libk5crypto.so.3.1
00daf000-00db0000 rwxp 00025000 fd:02 855009 /usr/lib/libk5crypto.so.3.1
044a0000-04580000 r-xp 00000000 fd:02 854460 /usr/lib/libstdc++.so.6.0.8
04580000-04584000 r-xp 000df000 fd:02 854460 /usr/lib/libstdc++.so.6.0.8
04584000-04585000 rwxp 000e3000 fd:02 854460 /usr/lib/libstdc++.so.6.0.8
04585000-0458b000 rwxp 04585000 00:00 0
08048000-08052000 r-xp 00000000 fd:02 66118 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/bin/java
08052000-08053000 rwxp 00009000 fd:02 66118 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/bin/java
08505000-0897e000 rwxp 08505000 00:00 0 [heap]
a9719000-a9720000 r-xs 00000000 fd:02 917751 /usr/lib/gconv/gconv-modules.cache
a9720000-a9750000 r-xp 00000000 fd:02 854451 /usr/lib/libidn.so.11.5.19
a9750000-a9751000 rwxp 0002f000 fd:02 854451 /usr/lib/libidn.so.11.5.19
a9751000-a9785000 r-xp 00000000 fd:02 66422 /usr/local/mapguideopensource/lib/liblib_json.so
a9785000-a9786000 rwxp 00034000 fd:02 66422 /usr/local/mapguideopensource/lib/liblib_json.so
a9786000-a97b6000 r-xp 00000000 fd:02 66428 /usr/local/mapguideopensource/lib/libproj.so.0.5.2
a97b6000-a97b8000 rwxp 0002f000 fd:02 66428 /usr/local/mapguideopensource/lib/libproj.so.0.5.2
a97b8000-a9b6b000 r-xp 00000000 fd:02 66425 /usr/local/mapguideopensource/lib/libgdal.so.1.11.4
a9b6b000-a9bba000 rwxp 003b3000 fd:02 66425 /usr/local/mapguideopensource/lib/libgdal.so.1.11.4
a9bba000-a9bbd000 rwxp a9bba000 00:00 0
a9bbd000-a9c61000 r-xp 00000000 fd:02 238615 /usr/local/mapguideopensource/webserverextensions/lib/libMgWebApp.so.7.0.0
a9c61000-a9c63000 rwxp 000a4000 fd:02 238615 /usr/local/mapguideopensource/webserverextensions/lib/libMgWebApp.so.7.0.0
a9c63000-aa015000 r-xp 00000000 fd:02 66431 /usr/local/mapguideopensource/lib/libxerces-c.so.27.0
aa015000-aa048000 rwxp 003b2000 fd:02 66431 /usr/local/mapguideopensource/lib/libxerces-c.so.27.0
aa048000-aa119000 r-xp 00000000 fd:02 753677 /usr/local/mapguideopensource/lib/libMgMdfParser.so.7.0.0
aa119000-aa11d000 rwxp 000d0000 fd:02 753677 /usr/local/mapguideopensource/lib/libMgMdfParser.so.7.0.0
aa11d000-aa19f000 r-xp 00000000 fd:02 753671 /usr/local/mapguideopensource/lib/libMgMdfModel.so.7.0.0
aa19f000-aa1a0000 rwxp 00081000 fd:02 753671 /usr/local/mapguideopensource/lib/libMgMdfModel.so.7.0.0
aa1a0000-aa311000 r-xp 00000000 fd:02 238621 /usr/local/mapguideopensource/webserverextensions/lib/libMgHttpHandler.so.7.0.0
aa311000-aa316000 rwxp 00171000 fd:02 238621 /usr/local/mapguideopensource/webserverextensions/lib/libMgHttpHandler.so.7.0.0
aa316000-aa48d000 r-xp 00000000 fd:02 753697 /usr/local/mapguideopensource/lib/libMgMapGuideCommon.so.7.0.0
aa48d000-aa493000 rwxp 00176000 fd:02 753697 /usr/local/mapguideopensource/lib/libMgMapGuideCommon.so.7.0.0
aa493000-aa494000 rwxp aa493000 00:00 0
aa494000-aa59b000 r-xp 00000000 fd:02 753692 /usr/local/mapguideopensource/lib/libMgPlatformBase.so.7.0.0
aa59b000-aa59f000 rwxp 00107000 fd:02 753692 /usr/local/mapguideopensource/lib/libMgPlatformBase.so.7.0.0
aa59f000-aa874000 r-xp 00000000 fd:02 753687 /usr/local/mapguideopensource/lib/libMgGeometry.so.7.0.0
aa874000-aa87a000 rwxp 002d5000 fd:02 753687 /usr/local/mapguideopensource/lib/libMgGeometry.so.7.0.0
aa87a000-aa87b000 rwxp aa87a000 00:00 0
aa87b000-aa964000 r-xp 00000000 fd:02 753681 /usr/local/mapguideopensource/lib/libMgFoundation.so.7.0.0
aa964000-aa968000 rwxp 000e8000 fd:02 753681 /usr/local/mapguideopensource/lib/libMgFoundation.so.7.0.0
aa968000-aaba2000 r-xp 00000000 fd:02 66421 /usr/local/mapguideopensource/lib/libACE.so
aaba2000-aabaf000 rwxp 00239000 fd:02 66421 /usr/local/mapguideopensource/lib/libACE.so
aabaf000-aabb1000 rwxp aabaf000 00:00 0
aabb1000-aae17000 r-xp 00000000 fd:02 238631 /usr/local/mapguideopensource/webserverextensions/lib/libMapGuideJavaApi.so.7.0.0
aae17000-aae1a000 rwxp 00266000 fd:02 238631 /usr/local/mapguideopensource/webserverextensions/lib/libMapGuideJavaApi.so.7.0.0
aae1a000-aae1d000 --xp aae1a000 00:00 0
aae1d000-aae6b000 rwxp aae1d000 00:00 0
aae6b000-aae6e000 --xp aae6b000 00:00 0
aae6e000-aaebc000 rwxp aae6e000 00:00 0
aaebc000-aaebf000 --xp aaebc000 00:00 0
aaebf000-aaf0d000 rwxp aaebf000 00:00 0
aaf0d000-aaf10000 --xp aaf0d000 00:00 0
aaf10000-aaf5e000 rwxp aaf10000 00:00 0
aaf5e000-aaf61000 --xp aaf5e000 00:00 0
aaf61000-aafaf000 rwxp aaf61000 00:00 0
aafaf000-aafb2000 --xp aafaf000 00:00 0
aafb2000-ab0f8000 rwxp aafb2000 00:00 0
ab0f8000-ab100000 --xp ab0f8000 00:00 0
ab100000-ab114000 r-xp 00000000 fd:02 919581 /usr/lib/libodbcinst.so.1.0.0
ab114000-ab115000 rwxp 00013000 fd:02 919581 /usr/lib/libodbcinst.so.1.0.0
ab11f000-ab121000 r-xs 00004000 fd:02 296231 /usr/local/mapguideopensource/webserverextensions/www/WEB-INF/lib/commons-fileupload-1.0.jar
ab121000-ab123000 r-xs 0000a000 fd:02 296233 /usr/local/mapguideopensource/webserverextensions/www/WEB-INF/lib/commons-codec-1.3.jar
ab123000-ab12c000 r-xs 00055000 fd:02 296286 /usr/local/mapguideopensource/webserverextensions/www/WEB-INF/lib/MapGuideApi.jar
ab12c000-ab12f000 --xp ab12c000 00:00 0
ab12f000-ab17d000 rwxp ab12f000 00:00 0
ab17d000-ab190000 r-xp 00000000 fd:02 35911 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/libnet.so
ab190000-ab191000 rwxp 00013000 fd:02 35911 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/libnet.so
ab191000-ab194000 r-xs 000cb000 fd:02 35864 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/ext/localedata.jar
ab194000-ab197000 r-xs 0000e000 fd:02 131283 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/tomcat-i18n-es.jar
ab197000-ab19a000 r-xs 0001c000 fd:02 131272 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/catalina-ha.jar
ab19a000-ab19c000 r-xs 00009000 fd:02 131284 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/tomcat-i18n-fr.jar
ab19c000-ab19f000 r-xs 00017000 fd:02 131276 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/jasper-el.jar
ab19f000-ab1ad000 r-xs 0010a000 fd:02 131274 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/catalina.jar
ab1ad000-ab1ae000 --xp ab1ad000 00:00 0
ab1ae000-ab22e000 rwxp ab1ae000 00:00 0
ab22e000-ab231000 --xp ab22e000 00:00 0
ab231000-ab27f000 rwxp ab231000 00:00 0
ab27f000-ab282000 --xp ab27f000 00:00 0
ab282000-ab3fc000 rwxp ab282000 00:00 0
ab3fc000-ab400000 --xp ab3fc000 00:00 0
ab400000-ab407000 r-xs 00077000 fd:02 131278 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/jasper.jar
ab407000-ab409000 r-xs 00014000 fd:02 131280 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/servlet-api.jar
ab409000-ab40d000 r-xs 0002d000 fd:02 131282 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/tomcat-dbcp.jar
ab40d000-ab40e000 r-xs 00002000 fd:02 131270 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/annotations-api.jar
ab40e000-ab413000 r-xs 00034000 fd:02 131273 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/catalina-tribes.jar
ab413000-ab41d000 r-xs 000ae000 fd:02 131281 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/tomcat-coyote.jar
ab41d000-ab429000 r-xs 00149000 fd:02 131277 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/jasper-jdt.jar
ab429000-ab42c000 --xp ab429000 00:00 0
ab42c000-ab47a000 rwxp ab42c000 00:00 0
ab47a000-ab67a000 r-xp 00000000 fd:02 855071 /usr/lib/locale/locale-archive
ab67a000-ab67d000 --xp ab67a000 00:00 0
ab67d000-ab6cb000 rwxp ab67d000 00:00 0
ab6cb000-ab6ce000 --xp ab6cb000 00:00 0
ab6ce000-ab71c000 rwxp ab6ce000 00:00 0
ab71c000-ab71d000 --xp ab71c000 00:00 0
ab71d000-ab7d0000 rwxp ab71d000 00:00 0
ab7d0000-ab966000 r-xs 02fb6000 fd:02 985998 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/rt.jar
ab966000-ab96d000 rwxp ab966000 00:00 0
ab96d000-ab987000 rwxp ab96d000 00:00 0
ab987000-ab98a000 rwxp ab987000 00:00 0
ab98a000-ab9a5000 rwxp ab98a000 00:00 0
ab9a5000-ab9a6000 rwxp ab9a5000 00:00 0
ab9a6000-ab9a7000 rwxp ab9a6000 00:00 0
ab9a7000-ab9aa000 rwxp ab9a7000 00:00 0
ab9aa000-ab9c5000 rwxp ab9aa000 00:00 0
ab9c5000-ab9cb000 rwxp ab9c5000 00:00 0
ab9cb000-ab9ef000 rwxp ab9cb000 00:00 0
ab9ef000-abaf0000 rwxp ab9ef000 00:00 0
abaf0000-abed0000 rwxp abaf0000 00:00 0
abed0000-ac2d0000 rwxp abed0000 00:00 0
ac2d0000-af9f0000 rwxp ac2d0000 00:00 0
af9f0000-b05f0000 rwxp af9f0000 00:00 0
b05f0000-b55f0000 rwxp b05f0000 00:00 0
b55f1000-b55f2000 r-xs 00006000 fd:02 131275 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/el-api.jar
b55f2000-b55f4000 r-xs 00011000 fd:02 131279 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/jsp-api.jar
b55f4000-b55f6000 r-xs 0000a000 fd:02 131285 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/tomcat-i18n-ja.jar
b55f6000-b55f7000 r-xs 00004000 fd:02 131264 /usr/local/mapguideopensource/webserverextensions/tomcat/bin/tomcat-juli.jar
b55f7000-b55f9000 r-xs 00001000 fd:02 131256 /usr/local/mapguideopensource/webserverextensions/tomcat/bin/commons-daemon.jar
b55f9000-b5600000 rwxp b55f9000 00:00 0
b5600000-b5679000 rwxp b5600000 00:00 0
b5679000-b5819000 rwxp b5679000 00:00 0
b5819000-b7679000 rwxp b5819000 00:00 0
b7679000-b7688000 r-xp 00000000 fd:02 35920 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/libzip.so
b7688000-b768a000 rwxp 0000e000 fd:02 35920 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/libzip.so
b768a000-b7693000 r-xp 00000000 fd:00 426023 /lib/libnss_files-2.5.so
b7693000-b7694000 r-xp 00008000 fd:00 426023 /lib/libnss_files-2.5.so
b7694000-b7695000 rwxp 00009000 fd:00 426023 /lib/libnss_files-2.5.so
b7695000-b7697000 r-xs 00003000 fd:02 131253 /usr/local/mapguideopensource/webserverextensions/tomcat/bin/bootstrap.jar
b7697000-b769f000 rwxs 00000000 fd:00 65546 /tmp/hsperfdata_root/8058
b769f000-b76c2000 r-xp 00000000 fd:02 35899 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/libjava.so
b76c2000-b76c4000 rwxp 00023000 fd:02 35899 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/libjava.so
b76c4000-b76cf000 r-xp 00000000 fd:02 35919 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/libverify.so
b76cf000-b76d0000 rwxp 0000b000 fd:02 35919 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/libverify.so
b76d0000-b76d3000 --xp b76d0000 00:00 0
b76d3000-b7721000 rwxp b76d3000 00:00 0
b7721000-b7b87000 r-xp 00000000 fd:02 35883 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/client/libjvm.so
b7b87000-b7ba7000 rwxp 00465000 fd:02 35883 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/client/libjvm.so
b7ba7000-b7fc9000 rwxp b7ba7000 00:00 0
b7fc9000-b7fca000 r-xs 0000b000 fd:02 131271 /usr/local/mapguideopensource/webserverextensions/tomcat/lib/catalina-ant.jar
b7fca000-b7fd0000 r-xp 00000000 fd:02 65545 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/native_threads/libhpi.so
b7fd0000-b7fd1000 rwxp 00006000 fd:02 65545 /usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/native_threads/libhpi.so
b7fd1000-b7fd2000 rwxp b7fd1000 00:00 0
b7fd2000-b7fd3000 r-xp b7fd2000 00:00 0
b7fd3000-b7fd4000 rwxp b7fd3000 00:00 0
b7fd4000-b7fd5000 r-xp b7fd4000 00:00 0 [vdso]
bf9cb000-bf9e0000 rwxp bffea000 00:00 0 [stack]
VM Arguments:
jvm_args: -Djava.util.logging.config.file=/usr/local/mapguideopensource/webserverextensions/tomcat/conf/logging.properties -Djava.library.path=/usr/local/mapguideopensource/webserverextensions/lib:/usr/local/mapguideopensource/lib -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.endorsed.dirs=/usr/local/mapguideopensource/webserverextensions/tomcat/endorsed -Dcatalina.base=/usr/local/mapguideopensource/webserverextensions/tomcat -Dcatalina.home=/usr/local/mapguideopensource/webserverextensions/tomcat -Djava.io.tmpdir=/usr/local/mapguideopensource/webserverextensions/tomcat/temp
java_command: org.apache.catalina.startup.Bootstrap start
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=/etc/alternatives/java_sdk
PATH=/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin
LD_LIBRARY_PATH=/usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386/client:/usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/lib/i386:/usr/lib/jvm/java-1.6.0-sun-1.6.0.17/jre/../lib/i386:/usr/local/mapguideopensource/webserverextensions/lib:/usr/local/mapguideopensource/lib
SHELL=/bin/bash
Signal Handlers:
SIGSEGV: [libjvm.so+0x3fc370], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x3fc370], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x325f30], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x325f30], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGXFSZ: [libjvm.so+0x325f30], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x325f30], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x328b20], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x328850], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGTERM: [libjvm.so+0x328850], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x328850], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:Red Hat Enterprise Linux Server release 5.4 (Tikanga)
uname:Linux 2.6.18-164.6.1.el5 #1 SMP Tue Oct 27 11:30:06 EDT 2009 i686
libc:glibc 2.5 NPTL 2.5
rlimit: STACK 10240k, CORE 0k, NPROC 2048, NOFILE 4096, AS infinity
load average:0.39 0.97 1.15
CPU:total 1 (8 cores per cpu, 1 threads per core) family 6 model 26 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2
Memory: 4k page, physical 2075500k(286792k free), swap 4192956k(4192892k free)
vm_info: Java HotSpot(TM) Client VM (14.3-b01) for linux-x86 JRE (1.6.0_17-b04), built on Oct 11 2009 01:17:07 by "java_re" with gcc 3.2.1-7a (J2SE release)
time: Mon Jan 25 16:49:02 2010
elapsed time: 24 seconds
__________________________________________________________________________________
Yahoo!7: Catch-up on your favourite Channel 7 TV shows easily, legally, and for free at PLUS7. www.tv.yahoo.com.au/plus7
