[mapguide-users] RE: Problem with map only half showing.
JamesDudden jamesdudden at blueyonder.co.uk
Fri Jan 29 09:39:51 EST 2010
Gary Morin wrote:
> Hi James
> Are you using OS Tif files? If so it could be a problem with the format,
> try using a utility like Irfanview to convert them.
Hi Gary,
Yes I am using OS Tif files so they should all be in the same format.
Why do I get this problem with some tiles every time and other tiles never?
Thanks
JD
http://www.software-matters.co.uk Software Matters  -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database  and Software Solutions
View this message in context: http://n2.nabble.com/Problem-with-map-raster-tif-files-only-half-showing-tp4473961p4480264.html
