[mapguide-users] RE: Problem with map only half showing.
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Sun Jan 31 14:09:00 EST 2010
Gary's comments reminded me of the solution - the issue is when the bottom
scan line of the raster is within the image. It's a GDAL issue and Frank W
confirmed it was an issue with the OS compression and the reader. The
solution was built into a GDAL patch / release.
It looks like you are on MG 2.0.2 still? That is GDAL 1.4 so a copy of the
GDAL v1.4.x latest (e.g. an old download of FWTools), stop the MG service
and replace the GDAL dll -- restart and you should be OK
Crispin
View this message in context: http://n2.nabble.com/Problem-with-map-raster-tif-files-only-half-showing-tp4473961p4490553.html
