[mapguide-users] Re: Guide Me in MGOS 2.1
Kenneth Skovhede ks at geograf.dk
Sun Jan 31 05:54:50 EST 2010
You need to remove the reference from within Visual Studio.
When you re-add the correct version, it will automatically update the
file when you press F5.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
>  Hi  Kenneth,
> Thanks for your reply .i have deleted the old version of
> MapguideDotNetApi.dll  and replaced the newer of version 1.0.0.1 but when i
> press f5 it olny takes the older version .i dont know why how it happens?
> 1) so for temporary solution i replaced the MapguideDotnetapi.dll of version
> 1.0.0.1 and makes as read only in property.so for temporarly the problem is
> solved  at Mgsite() and causes a new problem that webserver Unavailable is
> displayed on the browser.
>    so i checked the .Netframework from cmd prompt by typing aspnet_regiis -i
> but
> itsays that
> Failed to  Initialize the property so cx000005 errors occured.......... iam
> unable to find out whats happening to my system.i have uninstalled and
> reinstalled the framework 2.0 so problem solves at cmd prompt.While again
> running my application again says that "Webserver
> Unavailable"............................
> My system is running on
> MGOS 2.1
> IIS 6.0
> VS 2008 Express Edition
> .Net frame work 2.0
> Note:In iis i have setted the ASP.NET  as .Net frame work 2.0 to Mapguide
> virtual directory
> Regards,
> Padmini G.
