[mapguide-users] Re: Item X is already in this named collection
Jackie Ng
jumpinjackie at gmail.com
Mon Jul 5 09:10:24 EDT 2010
Although OSGeo.PostGIS and OSGeo.PostgreSQL are both FDO providers for
PostGIS databases. They are implemented differently and as a result:
- They require different connection parameters
- They have different naming conventions for schemas/classes/properties.
What this means is that your PostGIS layers will probably break if you
change your feature source from OSGeo.PostGIS to OSGeo.PostgreSQL or vice
versa.
Also note the general consensus is that OSGeo.PostGIS has been really
unreliable for production use, and if possible you should use the
OSGeo.PostgreSQL provider which is newer and will be getting more attention
from Autodesk.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Item-X-is-already-in-this-named-collection-tp5237836p5256002.html
