[mapguide-users] MGOS 2.1 crashes with MrSID plugin on Windows
2008
Homan, Thomas
thoman at co.gila.az.us
Mon Jul 12 10:09:33 EDT 2010
Not sure if this has relevance or not but I just finished up an issue
with MGE 2011 and SID imagery with Autodesk that sounds similar.
It seems that the latest generation of mrSid dlls do not support
composite mosaics. Applications hang with composite mosaics but work
fine once flattened. I've observed this behavior in the following
packages: MGE 2011 (2010 worked fine), Autocad MAP3d 2011 as well as
Lizardtech's free Geoviewer application.
Regards,
Tom
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
Sent: Monday, July 12, 2010 6:04 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MGOS 2.1 crashes with MrSID plugin on Windows
2008
Hello, we are using following configuration: - Windows 2008 (32 bit) -
IIS7 - MGOS 2.1 I have installed the MrSID plugin as described on
http://trac.osgeo.org/mapguide/wiki/MGOS21GdalProvider However when I
try to connect with a SID file (calling the layer or performing a test
connection) the mapguide server crashes and I get the error "cannot
establish connection". Debug information is providing no information. In
the trace.log last line is: MgServerResourceService:CheckPermission()
Also after having played around with permissions on the raster files the
server keeps crashing. I have successfully configured the MrSID plugin
before on a Windows 2003 server, but on Windows 2008 (32 bit) I have
this problem with two different servers. Anyone ideas whatelse I can try
View this message in context: MGOS 2.1 crashes with MrSID plugin on
Windows 2008
<http://osgeo-org.1803224.n2.nabble.com/MGOS-2-1-crashes-with-MrSID-plug
in-on-Windows-2008-tp5282797p5282797.html>
Sent from the MapGuide Users mailing list archive
<http://osgeo-org.1803224.n2.nabble.com/MapGuide-Users-f1803227.html>
at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100712/e1cebc1a/attachment.html
