[mapguide-users] MgFeatureReader.Close() doesnt close postgis connections
doggybs james.slater at keynetix.com
Tue Jul 13 12:59:59 EDT 2010
Hi All
I am using the following code in the Mapguide API to return a
MgFeatureReader to my postgis data source.
featureService.SelectFeatures(featureSourceId, classId.QualifiedClassName,
queryOptions);
I am using Mapguide2011 with FDO 3.5
When this command is executed I can see from postgis that a new connection
is opened. Running the following query in postgres show me the open
connections :
select * from pg_stat_activity;
Once i have finished. I call MgFeatureReader.Close(), but the connection to
postgis do not reduce?
Is this possible something to do with Connection  Pooling? or is there a
problem with my code, or Close function.
Many Thanks
James
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MgFeatureReader-Close-doesnt-close-postgis-connections-tp5288437p5288437.html
