[mapguide-users] Join with Oracle DB
sekko970
fabio.franceschini at techneteam.it
Mon Jul 26 11:49:22 EDT 2010
I have two data connections: the first is a connection to a SHP file, and the
second is an ODBC connection to an Oracle DB.
I extended my SHP with a table on Oracle DB using a database join, and I
created a layer that uses the join as feature source.
It seems all ok but when I try to use the joined properties (for example to
build the layer style), it causes the following error:
Error: An unclassified exception occurred.
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpSelectFeatures.Execute line 109 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpSelectFeatures.cpp
- MgServiceOperation.EndExecution line 533 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\base\ServiceOperation.cpp
- MgServerGwsFeatureReader.Serialize line 1061 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerGwsFeatureReader.cpp
- MgServerGwsGetFeatures.GetFeatures line 115 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerGwsGetFeatures.cpp
- MgServerGwsGetFeatures.GetMgClassDefinition line 277 file
The same thing but using SQLServer instead of Oracle works fine.
I'm using MGOS 2.0.2 and Oracle 9.2.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Join-with-Oracle-DB-tp5338542p5338542.html
