[mapguide-users] MGE 2011 64bit, Excel 2003 and Server 2008 R2
DGK kerrcad at gmail.com
Wed Jul 28 08:45:16 EDT 2010
Recently the forum helped me connect to an Excel 2003 file on a 2003 r2
server (32 bit).  We have now moved to a 2008 R2 server 64 bit with MGE 2011
64 bit and the problem resurfaced.
To get a successful connection test in Studio 2011, I installed the drivers
from this file, accessdatabaseengine_x64.exe, on the server on the advice of
"http://www.quattrosource.com/2010/03/microsoft-jet-drivers-for-64bit-windows-server-2008/".
This did not require the use of a server DSN connection and worked so long
as the "Type of database:" was set to "Microsoft Excel Driver (*.xls,
*.xlsx, *.xlsm, *.xlsb)".
There is still a problem with some of the data in the spreadsheet as a
preview of the data yeilds "An exception occurred in FDO component. RDBMS:
Incompatible column type", but a list of points alone works just fine.
I am going to add each column back in one at a time to see which one(s) are
causing a failure.  However any insight into the cause of this FDO exception
would be greatly appreciated.  While my trial and error may "fix" the
problem, I doubt I'll understand the root cause and would greatly appreciate
some educating or a link that will help me understand.
Thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MGE-2011-64bit-Excel-2003-and-Server-2008-R2-tp5345587p5345587.html
