[mapguide-users] MGES 2011 does not play with MGOS server 2.1
Trevor Wekel
trevor_wekel at otxsystems.com
Fri Jul 30 23:49:47 EDT 2010
Hi Jason,
MapGuide Studio 2011 has a 2.2.0.x version number, similar to MGOS 2.2. Obviously, Autodesk cannot officially support MGE 2011 connected to MGOS 2.2 since they are "slightly" different code streams. And you are absolutely correct, we may put something into MGOS that breaks compatibility at some point.
Having said all that, MapGuide Studio 2011 does successfully connect to MGOS 2.2 - at least for now.
Regards,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: July 30, 2010 8:58 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGES 2011 does not play with MGOS server 2.1
Are the version numbers similar? If Studio is doing specific version checking (it did at one point in the far past) could be running into problems.
I can't imagine Autodesk actually supporting Studio connected to MGOS. It's on a different cycle, and in some cases may even have breaking changes from MGE's release.
Jason
On 30 July 2010 14:50, Trevor Wekel wrote:
It should. The MGOS 2.2 Beta and MGE 2011 are similar code bases. MGOS 2.1 and MGE 2010 are also similar code bases.
Regards,
Trevor
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100730/3da5b0ce/attachment.html
