[mapguide-users] MapGuide 2.2 on Ubuntu 9.10
Zac Spitzer
zac.spitzer at ennoble.com.au
Wed Jun 2 06:49:35 EDT 2010
anything in the error logs?
was it apache or the mapguide server which crashed?
what kind of datasources and dataset's where you using?
2010/6/2 Pedro Venâncio <pedrongvenancio at yahoo.com>
> Hello Dave,
> You are right, I was missing to start the mapguide server. Now it's
> running!
> I've been doing some tests and find some instability. Within few hours,
> the server was down three times. Maestro also crashed several times. In
> windows I rarely had stability problems.
> I also could not make the connection to Postgis, like in 2.1 windows. Soon
> I will test the connection to Postgis with this beta version on windows.
> I'll keep trying!
> Thank you very much for your help!
> Pedro
> --- On *Tue, 6/1/10, Dave Wilson <dave.wilson at autodesk.com>* wrote:
> Did you run the mgserver.sh script as well to start the server process?
> You just run the Apache server.
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Pedro Venâncio
> *Sent:* Tuesday, June 01, 2010 3:23 PM
> *To:* MapGuide Users List
> *Subject:* [mapguide-users] MapGuide 2.2 on Ubuntu 9.10
> Hello everyone,
> First I would like to congratulate the efforts of developers to make a
> binary for ubuntu! This is excellent news, because long ago I had the idea
> of migrating MGOS to ubuntu, and this is the opportunity!
> I installed .deb packages of release 2.2 beta on a clean install of Ubuntu
> 9.10 (on a VirtualBox virtual machine), all without problems, running the
> script mginstallubuntu.sh. Then, I copied the phpviewersample-2.0 and
> Sheboygan.mgp to their directories on ubuntu and tried to access the Site
> Administrator, but without success. After running the command "sudo
> /usr/local/mapguideopensource/webserverextensions/apache2/bin/apachectl
> start", I've got access to the Site Administrator, but introducing the
> credentials ID: Administrator and Pass: admin, it shows this message: "Can
> not establish connection ". Then I tried to access through Maestro, but
> appeared the message of the image attached.
> I appreciate the help and apologize for this (probably) basic questiony,
> but I'm not an advanced ubuntu user.
> Thank you!
> Pedro
> -----Inline Attachment Follows-----
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org<http://mc/compose?to=mapguide-users@lists.osgeo.org>
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100602/6957bf75/attachment.html
