[mapguide-users] RE: How to render MgMultiGeometry
djonio
DJonio at miami-airport.com
Wed Jun 2 07:25:55 EDT 2010
Gunter,
In my case it appears to be an issue with S-L King 8.15. My MG byte reader
returns empty, fdo2fdo returns a _bad_ geometry error and the FDO Toolkit
returns a _null_ value. All seem to point to FDO.
After I read Julien’s post I got real serious and stepped through my code.
My SDF provider never gets a chance so I cannot now speak to that provider.
In fact my earlier comment about the KingOra provider being somewhat
successful with an insert was in error. I do the insert via ODP.NET and then
rely on KingOra to materialize the MG geometry which I then wish to use to
insert into SDF. Kinky stuff but there is method to the madness.
Yes, I would characterize your issue as a bug as opposed to an _undocumented
feature_. After all, if you can’t see it what is the point in mapping it?
As time permits I will do as Zak suggested and file an incident for my
KingOra issue. Hopefully you will have resolved the MG rendering issue by
the time that is resolved.
r,
dennis
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-render-MgMultiGeometry-tp5112715p5130297.html
