[mapguide-users] RE: How to render MgMultiGeometry
Zac Spitzer zac.spitzer at ennoble.com.au
Wed Jun 2 06:51:37 EDT 2010
it most definately a bug!
if you can attach a mgp which demonstrates the problem it would be great!
z
On 2 June 2010 18:17, Gunter Becker <gunter.becker at csogis.de> wrote:
> Hi Dennis, hi Zac,
> At the moment I'm just using the SDF Provider (no oracle test data needed,
> thanks). So, I assume that there are no FDO related issues in this provider.
> Like I said in my first post, I can write a MgMultiGeometry into the
> FeatureSource without any problem. Only problem I think is that it isn't
> rendered to the map image. I've realized that I cannot select any geometries
> from other layers that lie underneath the extent of the MgMultiGeometry
> feature. So, it is definitely at the right place but not rendered correctly.
> I think it's a bug, isn't it?
> Gunter
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-render-MgMultiGeometry-tp5112715p5129749.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
