[mapguide-users] Commercial Map Service Help
LLEUNDD
nuell at nicholsenvironmental.com
Wed Jun 2 13:38:12 EDT 2010
Hi Listers -
I have followed the instructions to add google maps to my fusion layout
here: http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
I have updated the index.html page to reflect the google maps key script as
outlined in step 1.
I have updated the coordinate system through maestro as outlined in step 2.
For Step 3 - I have the applicationdefinition file as follows:
<MapSet xsi:type="MapSetType">
<MapGroup id="googleBase">
<Map>
<Type>Google</Type>
<Extension>
<ResourceId>google</ResourceId>
</Extension>
</Map>
<Map>
<Type>MapGuide</Type>
<SingleTile>true</SingleTile>
<Extension>
<Options>
<isBaseLayer>false</isBaseLayer>
<useOverlay>true</useOverlay>
<projection>EPSG:900913</projection>
</Options>
<ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan-m.MapDefinition</ResourceId>
</Extension>
</Map>
</MapGroup>
</MapSet>
When I attempt to load the index.html file as the final step, Nothing loads
and I get the following error:
'maps' is null or not an object
Map.js
Code: 0
URI: http://xyz.com:8000/mapguide/fusion/lib/Map.js
Line: 220
Char: 23
I have followed the steps precisely multiple times and keep getting the same
error. Others have had success with this. Can anyone lend a helping hand?
Cheers!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Commercial-Map-Service-Help-tp5131790p5131790.html
