[mapguide-users] Commercial Map Service Help
Zac Spitzer zac.spitzer at gmail.com
Wed Jun 2 13:40:52 EDT 2010
software versions?
On 3 June 2010 03:38, LLEUNDD <nuell at nicholsenvironmental.com> wrote:
> Hi Listers -
> I have followed the instructions to add google maps to my fusion layout
> here: http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
> I have updated the index.html page to reflect the google maps key script as
> outlined in step 1.
> I have updated the coordinate system through maestro as outlined in step 2.
> For Step 3 - I have the applicationdefinition file as follows:
>  <MapSet xsi:type="MapSetType">
>    <MapGroup id="googleBase">
>    <Map>
>         <Type>Google</Type>
>         <Extension>
>              <ResourceId>google</ResourceId>
>         </Extension>
>    </Map>
>        <Map>
>         <Type>MapGuide</Type>
>         <SingleTile>true</SingleTile>
>         <Extension>
>              <Options>
>                   <isBaseLayer>false</isBaseLayer>
>                   <useOverlay>true</useOverlay>
>                   <projection>EPSG:900913</projection>
>              </Options>
> <ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan-m.MapDefinition</ResourceId>
>         </Extension>
>    </Map>
>        </MapGroup>
>  </MapSet>
> When I attempt to load the index.html file as the final step, Nothing loads
> and I get the following error:
> 'maps' is null or not an object
> Map.js
> Code: 0
> URI: http://xyz.com:8000/mapguide/fusion/lib/Map.js
> Line: 220
> Char: 23
> I have followed the steps precisely multiple times and keep getting the same
> error.  Others have had success with this.  Can anyone lend a helping hand?
> Cheers!
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Commercial-Map-Service-Help-tp5131790p5131790.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
