[mapguide-users] Re: Commercial Map Service Help
LLEUNDD
nuell at nicholsenvironmental.com
Thu Jun 3 15:11:43 EDT 2010
Hi Make - thanks for taking the time to help...
Your suggestion didn't work - The request to view the page resulted in the
same error as above ('maps' is null or not an object (in Maps.js Line 289
Char 23 in fusion/lib/Map.js)
I have attached three files to this response (index.html,
applicationdefinition.xml, applicationdefinition.xml.bak)
The index.html file has been edited to include the google script and key.
The applicationdefinition.xml file has been edited to show the googlebase
and sheboygan-m
The applicationdefinition.xml.bak is the original applicationdefinition.xml
file (just remove the .bak extension).
Any further help is greatly appreciated!
Cheers! http://osgeo-org.1803224.n2.nabble.com/file/n5136513/index.html
http://osgeo-org.1803224.n2.nabble.com/file/n5136513/ApplicationDefinition.xml
http://osgeo-org.1803224.n2.nabble.com/file/n5136513/ApplicationDefinition.xml.bak
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Commercial-Map-Service-Help-tp5131790p5136513.html
