[mapguide-users] Re: Commercial Map Service Help
Mike Adair
madair at dmsolutions.ca
Fri Jun 4 14:57:01 EDT 2010
I got your AppDef to work with Fusion trunk (essentially the same as
Fusion 2.0 RC1 at this point), the only change I had to make was to
point the MapWidget and Overview map at the MapGroup defined, ie. change
the <MapId> element for those widgets to be 'googleBase' rather than
'sheboygan' (Use the ID of the MapGroup element). The Overview didn't
actually show up but that's another issue
(http://trac.osgeo.org/fusion/ticket/373).
Mike
LLEUNDD wrote:
> Hi Make - thanks for taking the time to help...
> Your suggestion didn't work - The request to view the page resulted in the
> same error as above ('maps' is null or not an object (in Maps.js Line 289
> Char 23 in fusion/lib/Map.js)
> I have attached three files to this response (index.html,
> applicationdefinition.xml, applicationdefinition.xml.bak)
> The index.html file has been edited to include the google script and key.
> The applicationdefinition.xml file has been edited to show the googlebase
> and sheboygan-m
> The applicationdefinition.xml.bak is the original applicationdefinition.xml
> file (just remove the .bak extension).
> Any further help is greatly appreciated!
> Cheers! http://osgeo-org.1803224.n2.nabble.com/file/n5136513/index.html
> index.html
> http://osgeo-org.1803224.n2.nabble.com/file/n5136513/ApplicationDefinition.xml
> http://osgeo-org.1803224.n2.nabble.com/file/n5136513/ApplicationDefinition.xml.bak
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
http://www.dmsolutions.ca
http://research.dmsolutions.ca
