[mapguide-users] RE: Change image format from png to jpg
mapguide2010
Zac Spitzer
zac.spitzer at gmail.com
Fri Jun 4 02:49:37 EDT 2010
those settings will have zero effect
Mapguide doesn't serve titles with any http headers which would allow caching
bug http://trac.osgeo.org/mapguide/ticket/467
the only workaround is to serve the tiles via http using openlayers,
or put a proxy with some smart rules to add such headers to
gettile requests in front of the mapagent
z
On 4 June 2010 16:37, mighty_duck <msiljegovic at gmail.com> wrote:
> Hi Andy,
> thx for reply....I tried with png8 and it improve performance in case when
> I'm not using base layers. As I noticed, also you wrote in reply, those
> changes didnt have any influence on base layers. I used firebug and every
> tiles takes about 200KB in case of base layers, which is pretty much for a
> significant number of tiles(10 - 20). Also I noticed that when I pan on the
> map, it is obvious that it is remembering(caching) some tiles but after some
> time viewer is again loading tiles that already had been loaded(seems lose
> them).
> My questions are: do you know if it is somehow possible to improve
> performances of base layers? Does those parameters below in server.config
> file have any usage for base layers performance, does this parameter
> TileColumnsPerFolder determine number of tiles in cache folder on the server
> and maybe 30 in this case is restricting total number of files causingthat
> lost already loaded tiles(just thinking)?
> TileColumnsPerFolder = 30
> TileRowsPerFolder = 30
> DefaultTileSizeX = 300
> DefaultTileSizeY = 300
> And does anybody try , not related to MapGuide, to somehow remember one time
> loaded files( some browser capability) on the client side and then on
> requests first look into 'client cache' or something similar?
> Thx for any suggestions!
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Change-image-format-from-png-to-jpg-mapguide2010-tp5134979p5138272.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
