[mapguide-users] Mapguide OpenSource 2.2 backward compatibility
problem
Tom Fukushima
tom.fukushima at autodesk.com
Mon Jun 7 11:19:46 EDT 2010
Hi Bruno,
We try our best to retain backward compatibility, but in some cases it is just not possible. In this case the upgrade of PHP caused compilation errors because it had added a GetMessage method. The way we resolved this was to rename our GetMessage method to GetExceptionMethod. Unfortunately, you now have to pay the price for this change.
Tom
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Friday, June 04, 2010 12:43 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide OpenSource 2.2 backward compatibility problem
Hi All
We have a quite big MGOS application deployed on hundreds of different
clients
Most of them use MGOS 2.1 or MGE 2010 SP1
Some of them still use MGOS 2.0/1.2 or MGE 2010 / 2009
They will migrate to MGOS 2.2 or MGE 2011 but this process takes time so our
application
have to live in a multi version MGOS/MGE.
Now comes the problem with MGOS 2.2/MGE 2011
We use extensively the MgException::GetMessage() fonction
this function does not exist anymore because it is replaced by
GetExceptionMessage.
...stuff deleted...
Thanks for your answer.
Bruno
by the way, it would have been a lot easier for us if would have kept the
GetMessage function
for backward compatibility
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapguide-OpenSource-2-2-backward-compatibility-problem-tp5138292p5138292.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
