[mapguide-users] Re: [mapguide-internals] Fwd:
[mapguide-announce] MapGuide Open Source 2.2 beta released
Zac Spitzer
zac.spitzer at gmail.com
Tue Jun 8 03:00:16 EDT 2010
see inline
On 8 June 2010 16:47, Jason Birch <jason at jasonbirch.com> wrote:
> Zac, are there any other services running under the same userid as
> MapGuide? Not requiring the cs-map env var means that either
> something has changed with how Windows loads the profile for the
> services, or that userid hadn't been logged in as a service yet.
it's just running out of the box as system ... i only tested the sheboygan
sample and have subsequently rebooted anyway
personally i think having CSMAP would of been better as a default
serverconfig item.... but thats another story :)
> On 2010-06-07, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> Just installed on my new windows 7 64-bit machine (bundled apache
>> config with php)
>> and it all works fine... dind't even need to reboot, just had to
>> manually start the
>> apache service.... very zippy indeed
>> anyone trying this who wants to use studio, should follow this tip
>> to set the 32 bit flag for studio....
>> http://mapguide.wordpress.com/2009/12/15/mapguide-studio-2010-with-64-bit/
>> z
>> On 4 June 2010 13:14, Jackie Ng <jumpinjackie at gmail.com> wrote:
>>> Could you create a trac ticket with an attached MSI log of the failed
>>> installation?
>>> To enable MSI logging run the internal msi as so:
>>> msiexec /l*v install.log /i <name of the msi>
>>> The exe installer is just a self-extracting executable. You should be able
>>> to extract the internal msi using 7-zip (http://7-zip.org)
>>> - Jackie
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/MapGuide-Open-Source-2-2-beta-released-tp5126722p5137912.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
Zac Spitzer
+61 405 847 168
