[mapguide-users] Re: [mapguide-internals] Fwd: [mapguide-announce]
MapGuide Open Source 2.2 beta released
Jason Birch
jason at jasonbirch.com
Tue Jun 8 03:37:41 EDT 2010
No debate there, though it would have to be set in both webconfig and
serverconfig. There was some discussion on this around the 2.1
release, but I think it just trailed off.
On 2010-06-08, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> see inline
> On 8 June 2010 16:47, Jason Birch <jason at jasonbirch.com> wrote:
>> Zac, are there any other services running under the same userid as
>> MapGuide? Not requiring the cs-map env var means that either
>> something has changed with how Windows loads the profile for the
>> services, or that userid hadn't been logged in as a service yet.
> it's just running out of the box as system ... i only tested the sheboygan
> sample and have subsequently rebooted anyway
> personally i think having CSMAP would of been better as a default
> serverconfig item.... but thats another story :)
>> On 2010-06-07, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>>> Just installed on my new windows 7 64-bit machine (bundled apache
>>> config with php)
>>> and it all works fine... dind't even need to reboot, just had to
>>> manually start the
>>> apache service.... very zippy indeed
>>> anyone trying this who wants to use studio, should follow this tip
>>> to set the 32 bit flag for studio....
>>> http://mapguide.wordpress.com/2009/12/15/mapguide-studio-2010-with-64-bit/
>>> z
>>> On 4 June 2010 13:14, Jackie Ng <jumpinjackie at gmail.com> wrote:
>>>> Could you create a trac ticket with an attached MSI log of the failed
>>>> installation?
>>>> To enable MSI logging run the internal msi as so:
>>>> msiexec /l*v install.log /i <name of the msi>
>>>> The exe installer is just a self-extracting executable. You should be
>>>> able
>>>> to extract the internal msi using 7-zip (http://7-zip.org)
>>>> - Jackie
>>>> View this message in context:
>>>> http://osgeo-org.1803224.n2.nabble.com/MapGuide-Open-Source-2-2-beta-released-tp5126722p5137912.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer
>>> Solution Architect / Director
>>> Ennoble Consultancy Australia
>>> http://www.ennoble.com.au
>>> http://zacster.blogspot.com
>>> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
