[mapguide-users] Re: Tool tip issue
LLEUNDD nuell at nicholsenvironmental.com
Tue Jun 8 14:16:09 EDT 2010
Never Mind -
I found out that the order in which you place your <map> contents affects
the issue above.  I placed the google <map> below the <map> with the library
mapdefinition.
Thanks again for all the help!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Tool-tip-issue-tp5150518p5154882.html
