[mapguide-users] Re: Tool tip issue
LLEUNDD
nuell at nicholsenvironmental.com
Tue Jun 8 12:04:48 EDT 2010
The layer I am trying to hit is called "ClientLocations". I changed the
MapTip widget in the applicationdefinition to this rather than "Parcels". I
reloaded the webpage and the maptips still don't work.
I played around with the whole set up a little over night and found the
following:
- I save the weblayout in MG Studio as an xml. When I place that xml into
the following folder
/mapguide/fusion/templates/mapguide/client/
and load the index.html webpage through
www.example.com/mapguide/fusion/templates/mapguide/Client/, everything works
(i.e., I can select points and see the information, I can hover and see the
tooltip for the features, etc.) The mapdefinition for the weblayout only
has a single point layer.
- when I add the following code to the above applicationdefinition
<MapGroup id="ClientMap">
<Map>
<Type>Google</Type>
<Extension>
<ResourceId>google</ResourceId>
<Options>
<type>G_PHYSICAL_MAP</type>
</Options>
</Extension>
</Map>
<Map>
<Type>MapGuide</Type>
<SingleTile>true</SingleTile>
<Extension>
<Options>
<isBaseLayer>false</isBaseLayer>
<useOverlay>true</useOverlay>
<projection>EPSG:900913</projection>
</Options>
<ResourceId>Library://testing/Maps/ClientMap.MapDefinition</ResourceId>
</Extension>
</Map>
<Extension />
</MapGroup>
The google map will load with the points layer visible, however I can no
longer select and get information from a point and can not get the tool tip
to appear for the points.
My thinking is that the option <isBaseLayer>false</isBaseLayer> is messing
things up. I also have a custom widget that searches the point layer based
on ID. This widget works without google commercial layer, but fails with
the google commercial layer. The error I get is:
Object doesn't support this property or method
fusionSF-compressed.js
I have attached the application definition and index file to this post. I
am using Fusion version 2.0.0-RC1.
Any help is appreciated!
http://osgeo-org.1803224.n2.nabble.com/file/n5154358/ApplicationDefinition.xml
http://osgeo-org.1803224.n2.nabble.com/file/n5154358/index.html index.html
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Tool-tip-issue-tp5150518p5154358.html
