[mapguide-users] Re: MGOS 2.2 on Windows 2008 Server - Problem connecting from Maestro
David Collins david.8.collins at gmail.com
Wed Jun 9 21:12:41 EDT 2010
Forgot to add - I am able to successfully create a Dataconnection to a
shapefile that I added to MGOS.
The problem seems to be specific to adding a Spatial SQL Server
dataconnection.
On Thu, Jun 10, 2010 at 10:59 AM, David Collins
<david.8.collins at gmail.com>wrote:
> Hello.
> *MGOS 2.2.0.4829-Beta1
> Maestro 2.0.0.4650
> Bundled Apache/PHP*
> I have downloaded the latest SQL Server Native Client, and installed it.
> (sqlncli.msi)
> Immediately after starting Maestro and successfully connecting to MGOS 2.2,
> I try to create a new Spatial SQL Server 'Dataconnection', I enter the
> details - SQL Server name\instance, database & credentials
> When I click *'Test Connection'*, I get the following ..
> The remote server returned an error: (559) MgConnectionFailedException.:
> Problem:\nCannot establish connection to the MapGuide Server.\n\nPossible
> Causes:\n-Your session has been idle for too long;\n-MapGuide Server is no
> longer responding;\n-Internet connection problems.\n\nSolution:\nRestart
> your application / session, restart the MapGuide Server service, or contact
> with the server administrator.
> I shutdown Maestro, restart MapGuide ...
> C:\GI\Doco>net stop "MapGuide Server 2.2"
> The MapGuide Server 2.2 service is stopping.
> The MapGuide Server 2.2 service was stopped successfully.
> C:\GI\Doco>net start "MapGuide Server 2.2"
> The MapGuide Server 2.2 service is starting.
> The MapGuide Server 2.2 service was started successfully.
> Open Maestro, and do the same again, and get the same error.
> Regards,
> David
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100610/1f794b8b/attachment.html
