[mapguide-users] Re: MGOS 2.2 on Windows 2008 Server - Problem
connecting from Maestro
Zac Spitzer
zac.spitzer at gmail.com
Wed Jun 9 21:21:46 EDT 2010
I'd suggest posting this question on fdo-users as it's a specific FDO question
On 10 June 2010 11:12, David Collins <david.8.collins at gmail.com> wrote:
> Forgot to add - I am able to successfully create a Dataconnection to a
> shapefile that I added to MGOS.
> The problem seems to be specific to adding a Spatial SQL Server
> dataconnection.
> On Thu, Jun 10, 2010 at 10:59 AM, David Collins <david.8.collins at gmail.com>
> wrote:
>> Hello.
>> MGOS 2.2.0.4829-Beta1
>> Maestro 2.0.0.4650
>> Bundled Apache/PHP
>> I have downloaded the latest SQL Server Native Client, and installed it.
>> (sqlncli.msi)
>> Immediately after starting Maestro and successfully connecting to MGOS
>> 2.2, I try to create a new Spatial SQL Server 'Dataconnection', I enter the
>> details - SQL Server name\instance, database & credentials
>> When I click 'Test Connection', I get the following ..
>> The remote server returned an error: (559) MgConnectionFailedException.:
>> Problem:\nCannot establish connection to the MapGuide Server.\n\nPossible
>> Causes:\n-Your session has been idle for too long;\n-MapGuide Server is no
>> longer responding;\n-Internet connection problems.\n\nSolution:\nRestart
>> your application / session, restart the MapGuide Server service, or contact
>> with the server administrator.
>> I shutdown Maestro, restart MapGuide ...
>> C:\GI\Doco>net stop "MapGuide Server 2.2"
>> The MapGuide Server 2.2 service is stopping.
>> The MapGuide Server 2.2 service was stopped successfully.
>> C:\GI\Doco>net start "MapGuide Server 2.2"
>> The MapGuide Server 2.2 service is starting.
>> The MapGuide Server 2.2 service was started successfully.
>> Open Maestro, and do the same again, and get the same error.
>> Regards,
>> David
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
