[mapguide-users] WMS failure - The coordinate system load failed
Joel Carranza jec at gatekeeper.com
Thu Jun 10 15:01:19 EDT 2010
I've run across a problem when accessing MapGuide layers via WMS. My map
projection is UTM zone 17N, so I setup the two layers with EPSG:2958 by
specifying "Bounds" and "Other SRS" in the layer properties dialog in Map
Guide Studio. The default global WMS projection is unchanged.
When I make WMS requests, I intermittently get the following error.
<ServiceExceptionReport version="1.1.1">
 <ServiceException code="InternalError"> The coordinate system load failed.
CSRS.UTM-17N
 <details>The coordinate system load failed. CSRS.UTM-17N </details>
</ServiceException>
</ServiceExceptionReport>
The same URL doesn't necessarily fail twice, and am I making multiple WMS
requests simultaneously, so I assumed it was some kind of  concurrency
problem. Sure enough, when I serialize the requests I don't see the error.
When I change the default WMS projections as per instructions @
http://sandbox.mapguide.com/index.php/Web_Mapping_Service
I continue to have the same problem
(as an aside, another small gotcha the reported error is never reported in
the error log)
Doh! Any suggestions?
--joel
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WMS-failure-The-coordinate-system-load-failed-tp5164799p5164799.html
