[mapguide-users] WMS failure - The coordinate system load failed
Dave Wilson
dave.wilson at autodesk.com
Thu Jun 10 16:31:53 EDT 2010
It sounds like you've encountered a bug. The error likely isn't logged because the error is occurring on the Web Tier and not in the Server.
I would log a trac ticket with a package of your data sources if that's possible.
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joel Carranza
Sent: Thursday, June 10, 2010 1:01 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] WMS failure - The coordinate system load failed
I've run across a problem when accessing MapGuide layers via WMS. My map
projection is UTM zone 17N, so I setup the two layers with EPSG:2958 by
specifying "Bounds" and "Other SRS" in the layer properties dialog in Map
Guide Studio. The default global WMS projection is unchanged.
When I make WMS requests, I intermittently get the following error.
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InternalError"> The coordinate system load failed.
CSRS.UTM-17N
<details>The coordinate system load failed. CSRS.UTM-17N </details>
</ServiceException>
</ServiceExceptionReport>
The same URL doesn't necessarily fail twice, and am I making multiple WMS
requests simultaneously, so I assumed it was some kind of concurrency
problem. Sure enough, when I serialize the requests I don't see the error.
When I change the default WMS projections as per instructions @
http://sandbox.mapguide.com/index.php/Web_Mapping_Service
I continue to have the same problem
(as an aside, another small gotcha the reported error is never reported in
the error log)
Doh! Any suggestions?
--joel
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WMS-failure-The-coordinate-system-load-failed-tp5164799p5164799.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
