[mapguide-users] Re: Fusion: 'map' is null ...
CroNicoRn ah_jid at yahoo.com
Wed Jun 16 23:39:25 EDT 2010
http://osgeo-org.1803224.n2.nabble.com/file/n5189239/002.jpg
//create the 'Map' layer widgets defined in the MapGroup
        this.aMaps = [];
        this.mapGroup = mapGroup;
        for (var i=0; i<mapGroup.maps.length; ++i) {
          var mapTag = mapGroup.maps[i];
          if (Fusion.Maps[mapTag.type]) {
              this.aMaps[i] = eval("new
Fusion.Maps."+mapTag.type+"(this,mapTag)");
              this.layerRoot.addGroup(this.aMaps[i].layerRoot);
          } else {
              //TODO: we can add more OpenLayers layers ...
        $(name).widget = this;
        this.registerEventID(Fusion.Event.MAP_EXTENTS_CHANGED);
        this.registerEventID(Fusion.Event.MAP_BUSY_CHANGED);
        this.registerEventID(Fusion.Event.MAP_GENERIC_EVENT);
        this.registerEventID(Fusion.Event.MAP_RESIZED);
        this.registerEventID(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED);
        this.registerEventID(Fusion.Event.MAP_LOADED);
        this.registerEventID(Fusion.Event.MAP_LOADING);
        this.registerEventID(Fusion.Event.MAP_RELOADED);
        this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
        this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
Fusion Version on Mapguide Enterprise 2009, Maestro 2.0
http://www.myguidepages.com  http://n2.nabble.com/file/u115131/ajid.jpg
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-map-is-null-tp5189015p5189239.html
