[mapguide-users] Re: Fusion: 'map' is null ...
pcardinal
pierre.cardinal at sympatico.ca
Thu Jun 17 19:30:19 EDT 2010
If you are using the file ApplicationDefinition.xml, what's in it? Or what's
in your ApplicationDefinition ressource (XML)? The problem could be within
the <MapSet>. In fact to avoid this problem, MapGuide should find in the XML
a <MapWidget> with a <MapId> having the name of the ID of the <MapGroup> in
<MapSet>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-map-is-null-tp5189015p5193413.html
