Hi I have the following message with Explorer (Fusion Layout, Localized in french): "Could not find Fusion instance". The error seem to be in index.html (in the Fusion template) line 48: "Fusion.initializeLocale(); //need to call this first if String.Translate is to be used in the onload Any idea? Martin F
