[mapguide-users] Fusion, Localize and Explorer
Mike Adair madair at dmsolutions.ca
Fri Jun 18 13:54:40 EDT 2010
Just a guess because you haven't provided much information, but the
Fusion object will only be defined after all the script tags are
loaded.  i.e. you need to call that method from a window.onload callback.
Mike
Martin Fafard wrote:
> Hi
> I have the following message with Explorer (Fusion Layout, Localized
> in french):
> "Could not find Fusion instance".
> The error seem to be in index.html (in the Fusion template) line 48:
> "Fusion.initializeLocale(); //need to call this first if
> String.Translate is to be used in the onload
> Any idea?
> Martin F
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
