[mapguide-users] Fusion, Localize and Explorer
Martin Fafard
martin.fafard at geoprojection.com
Sat Jun 19 11:45:15 EDT 2010
Thank you Mike
Yes, I call that method with window.onload.
It's like Explorer can't reach fusion.js...??
Martin F
Mike Adair a écrit :
> Just a guess because you haven't provided much information, but the
> Fusion object will only be defined after all the script tags are
> loaded. i.e. you need to call that method from a window.onload callback.
> Mike
> Martin Fafard wrote:
>> Hi
>> I have the following message with Explorer (Fusion Layout, Localized
>> in french):
>> "Could not find Fusion instance".
>> The error seem to be in index.html (in the Fusion template) line 48:
>> "Fusion.initializeLocale(); //need to call this first if
>> String.Translate is to be used in the onload
>> Any idea?
>> Martin F
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
