[mapguide-users] Packaging MrSID file (10gb) for use in Autodesk
MGE 2010 (Newbie Alert!)
Jason Birch
jason at jasonbirch.com
Tue Jun 22 20:55:33 EDT 2010
One hack would be to package up a smaller MrSID with the same name, figure
out where on the server it ends up (in one of the subdirectories of
Server/Repositories/Library/DataFiles), and overwrite it with the full-sized
one.
I much prefer using unmanaged data resource though (see Tom's pointer),
especially for large files; keeps the package size smaller and easy to port
between servers and (IMO) makes data backup/restore easier.
To import large packages, you can place the .mgp file on the server under
the Packages folder and import in the admin tool's package management area.
This avoids maximum upload file size constraints. In your case though, I
believe you are running into the maximum MGP file size, which may be as low
as 2GB...
Jason
On 22 June 2010 12:00, Dan Kerr wrote:
> If attempt to make package of 10gb MrSID in MG Studio, get maximum file
> size exceeded error.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100622/c0ff10df/attachment.html
