[mapguide-users] Packaging MrSID file (10gb) for use in Autodesk
MGE 2010 (Newbie Alert!)
Zac Spitzer
zac.spitzer at gmail.com
Tue Jun 22 23:46:19 EDT 2010
Studio (2010) will run on Windows 7 64 bit, you just need to run
corflags /+32bit
http://mapguide.wordpress.com/2009/12/15/mapguide-studio-2010-with-64-bit/
Studio 2011 runs in 64 bit natively (well without the hack...) BTW
On 23 June 2010 10:55, Jason Birch <jason at jasonbirch.com> wrote:
> One hack would be to package up a smaller MrSID with the same name, figure
> out where on the server it ends up (in one of the subdirectories of
> Server/Repositories/Library/DataFiles), and overwrite it with the full-sized
> one.
> I much prefer using unmanaged data resource though (see Tom's pointer),
> especially for large files; keeps the package size smaller and easy to port
> between servers and (IMO) makes data backup/restore easier.
> To import large packages, you can place the .mgp file on the server under
> the Packages folder and import in the admin tool's package management area.
> This avoids maximum upload file size constraints. In your case though, I
> believe you are running into the maximum MGP file size, which may be as low
> as 2GB...
> Jason
> On 22 June 2010 12:00, Dan Kerr wrote:
>> If attempt to make package of 10gb MrSID in MG Studio, get maximum file
>> size exceeded error.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
