[mapguide-users] Re: Packaging MrSID file (10gb) for use in Autodesk MGE 2010 (Newbie Alert!)
Zac Spitzer zac.spitzer at gmail.com
Wed Jun 23 09:28:31 EDT 2010
Trevor suggested http://www.globalmapper.com/ as a nice for cutting up rasters
a while ago, it's worked really well for me and is only $400 usd or the like
On 23 June 2010 23:22, DGK <kerrcad at gmail.com> wrote:
> Jason Birch wrote:
>> In your case though, I believe you are  running into the maximum MGP file
>> size, which may be as low
>> as 2GB...
>> Jason
>> On 22 June 2010 12:00, Dan Kerr wrote:
>>> If attempt to make package of 10gb MrSID in MG Studio, get maximum file
>>> size exceeded error.
> I believe you are correct about the 2gb MGP file limit.  The failures from
> multiple creation attempts were always nearly, but not quite, 2gb.
> After reading the up on the resources posted by Tom (above) and the 2010
> courseware provided by a link from zspitzer (also above) I may be back
> asking how to break up a MrSid file.
> But for right now I have enough to do.
> Thanks,
> Dan
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Packaging-MrSID-file-10gb-for-use-in-Autodesk-MGE-2010-Newbie-Alert-tp5210668p5213222.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
