[mapguide-users] Re: call javascript:window.open inside a tooltip
Wilson Herrera
wherrera at pccadpanama.com
Wed Jun 23 17:10:30 EDT 2010
in fact, you can put javascript anywhere.
according to this page
http://themapguyde.blogspot.com/2009/07/expressive-power-of-mapguide-tooltips.html
a tooltip is only another
tag, so i would be able to inject javascript code in the old fashion like
this (actual tooltip in the layer definition):
"javascript:window.open('index.html',null,'menubar=no');"
this javascript is used in a onclick property on a image whithin the
toooltip (i can't post the code because i dont know how to insert html code
here).
if i use, lets say, a alert
like: javascript:alert("hello");
if works fine, but in the code provided above it, it simply throws an error.
i tried escaping the text (\'') to no avail.
maybe should i specify this javascript inside the fusion index.html itself?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/call-javascript-window-open-inside-a-tooltip-tp5214817p5215227.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100623/7747879d/attachment.html
