[mapguide-users] Re: call javascript:window.open inside a tooltip
Jackie Ng
jumpinjackie at gmail.com
Wed Jun 23 20:26:44 EDT 2010
FYI I wrote that blog post ;-)
I think this is more of an implementation detail here. Tooltips for the AJAX
and Fusion viewers can display any arbitrary HTML content, but the there are
subtle differences in how tooltips behave:
- Fusion tooltips "stick", allowing you to interact with the tooltip
content.
- AJAX tooltips do not "stick", so it is impossible to interact with the
tooltip content.
There may be other differences as well, which may be affecting your
tooltip's behaviour.
My blog post was originally focused on the AJAX viewer, so this may be a
Fusion-specific problem (I'm assuming you're using Fusion here?). Perhaps
you may get a better answer from the Fusion mailing list.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/call-javascript-window-open-inside-a-tooltip-tp5214817p5215765.html
