[mapguide-users] Re: call javascript:window.open inside a tooltip
Zac Spitzer zac.spitzer at gmail.com
Thu Jun 24 10:37:54 EDT 2010
Can't you just call a function, rather than putting so much code in the
tooltip? Much cleaner, easier and more efficient
On 25 Jun 2010 00:34, "Wilson Herrera" <wherrera at pccadpanama.com> wrote:
> wow i haven't noticed, small world after all.
> yes, in fact i have been using fusion, but i think my main problem is the
> ' " symbol, because i need it to specify the parameters of the window.open
> function, but mapguide in their tooltip definition uses it to define
> strings, so, when i try to use the symbol it just ends the string and wont
> allow me to continue, so i escape the symbol ( using \'') but then,
internet
> explorer throws an error.
> have checked in firefox and it works fine!
> what can be done then?
> i will post this question to the fusion mailing list too, if i get an
> answer, will post it here.
> thank you for your advice!
http://osgeo-org.1803224.n2.nabble.com/call-javascript-window-open-inside-a-tooltip-tp5214817p5217404.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100625/fd053d97/attachment.html
