[mapguide-users] Re: Unable to hide layers
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Mar 2 05:13:41 EST 2010
IIRC there is a difference in how GETMAPIMAGE and GETDYNAMICOVERLAYIMAGE
handles the HIDELAYERS / SHOWLAYERS paramter.
Have you verified that the request sent to MapGuide is correct?
What happens if you use the opposite OPERATION parameter?
Previous to MGOS 2.1 you need to call the GETVISIBLEMAPEXTENT before
using GETDYNAMICOVERLAYIMAGE.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc56
IIRC there is an option to toggle MGOS 2.1 and 2.0 in the OL mapguide
layer class.
Even if you think fusion is a bit much, perhaps you can try setting up a
sample map/layout and
toggle a layer to see if the request(s) sent to MG is different than
what you are sending?
Regards, Kenneth Skovhede, GEOGRAF A/S
On 02-03-2010 10:31, durrrr wrote:
> sorry - misunderstanding. All of the layers are set to visible in Maestro
