[mapguide-users] Re: Strange behaviour with labels in Mapguide.
Help needed.
JamesDudden
jamesdudden at blueyonder.co.uk
Fri Mar 5 06:49:08 EST 2010
Thanks for the continued help Dave,
I have compared the 2 xml files and there were a couple of small differences
so I amended the sdf file to be the same as the dwg to be the same (apart
from name and geometry) but it still gives me the same problem.
The only thing that is different now is the geometry - could this be causing
the problem?
Below is the geometric properties of the dwg:
Property Name Geometry
Property Type point curve surface
Has Measures false
Has Elevation false
Below is the geometric properties of the sfd:
Property Name Geom
Has Measures false
Has Elevation true
Any other thoughts?
I can't believe I'm the only person seeing this happen??
http://www.software-matters.co.uk Software Matters -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database and Software Solutions
View this message in context: http://n2.nabble.com/Strange-behaviour-with-labels-in-Mapguide-Help-needed-tp4673228p4680338.html
