[mapguide-users] Re: Simple OGR FDO question
Traian Stanev traian.stanev at autodesk.com
Thu Mar 11 17:03:21 EST 2010
I'm not 100% sure, but I think GDAL/OGR (not the FDO provider, GDAL itself) needs to be compiled with some specific settings in order to have KML support. You may have to replace the GDAL DLL for FDO with one that has KML support compiled in it.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jamo
Sent: Thursday, March 11, 2010 4:10 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: Simple OGR FDO question
Kenneth.
I thought it would be that easy however ... I get the following error when
testing the connection in maestro
2010-03-12T07:00:17> 	3188	MapGuide Maestro v2.0.0.4586	172.16.40.28
Administrator
 Error: An exception occurred in FDO component.
        Connect failed:
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation() line 83 file
d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpTestFeatureSourceConnection.Execute() line 100 file
d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\OpTestFeatureSourceConnection.cpp
  - MgFdoConnectionManager.Open() line 900 file
d:\Build\Testarossa_Nightly\BUILD_30.1\Ent\OS\Server\src\Common\Manager\FdoConnectionManager.cpp
The file in question can be found in this google earth network link
http://www.marinetraffic.com/ais/ge.aspx
which calls this page http://marinetraffic2.aegean.gr/ais/getkml.aspx
I have extracted the kml document form the kmz prior to testing in mapguide.
any thoughts?
Jason.
I'm using Mapguide Enterprise 2010 Do I have to recompile the SL.King.KML
provider to function with my version of FDO? I haven't tried the provider
yet but I'm not sure on how the FDO versions effect seperate providers built
for different versions of FDO.
View this message in context: http://n2.nabble.com/Simple-OGR-FDO-question-tp4714152p4718727.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
