[mapguide-users] Re: Simple OGR FDO question
Jamo adam.jamison at portbris.com.au
Thu Mar 11 16:09:34 EST 2010
Kenneth.
I thought it would be that easy however ... I get the following error when
testing the connection in maestro
2010-03-12T07:00:17> 	3188	MapGuide Maestro v2.0.0.4586	172.16.40.28
Administrator
 Error: An exception occurred in FDO component.
        Connect failed:
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation() line 83 file
d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpTestFeatureSourceConnection.Execute() line 100 file
d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\OpTestFeatureSourceConnection.cpp
  - MgFdoConnectionManager.Open() line 900 file
d:\Build\Testarossa_Nightly\BUILD_30.1\Ent\OS\Server\src\Common\Manager\FdoConnectionManager.cpp
The file in question can be found in this google earth network link
http://www.marinetraffic.com/ais/ge.aspx
which calls this page http://marinetraffic2.aegean.gr/ais/getkml.aspx
I have extracted the kml document form the kmz prior to testing in mapguide.
any thoughts?
Jason.
I'm using Mapguide Enterprise 2010 Do I have to recompile the SL.King.KML
provider to function with my version of FDO? I haven't tried the provider
yet but I'm not sure on how the FDO versions effect seperate providers built
for different versions of FDO.
View this message in context: http://n2.nabble.com/Simple-OGR-FDO-question-tp4714152p4718727.html
