[mapguide-users] Simple OGR FDO question
Jason Birch
jason at jasonbirch.com
Thu Mar 11 04:31:55 EST 2010
You could also try Haris' FDO Provider for KML, which is available on
the SL-King website.
Jason
On 2010-03-11, Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk> wrote:
> If you create a new OGR featuresource, simply set the "DataSource"
> parameter to point to the KML file.
> Be sure to set "ReadOnly" to TRUE.
> If you use Maestro, you can upload the file, or enter the path to the
> KML file in the UI.
> Behind the scenes it just sets the DataSource parameter for you.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> On 11-03-2010 06:18, Jamo wrote:
>> Can Mapguide use KML as a datastore to grab information from?
>> If so how do i connect to the KML using OGR?
>> I'm trying to load some point data from a kml file and I'm not sure if it
>> is
>> just corrupt data or not..
>> I've been playing around with the FDO api and if it isn't possible I can
>> always run punch the kml file into a SDF.
>> Would be easier if it could be read directly into Mapguide though.
>> Cheers
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
