[mapguide-users] Simple OGR FDO question
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Mar 11 03:11:21 EST 2010
If you create a new OGR featuresource, simply set the "DataSource"
parameter to point to the KML file.
Be sure to set "ReadOnly" to TRUE.
If you use Maestro, you can upload the file, or enter the path to the
KML file in the UI.
Behind the scenes it just sets the DataSource parameter for you.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 11-03-2010 06:18, Jamo wrote:
> Can Mapguide use KML as a datastore to grab information from?
> If so how do i connect to the KML using OGR?
> I'm trying to load some point data from a kml file and I'm not sure if it is
> just corrupt data or not..
> I've been playing around with the FDO api and if it isn't possible I can
> always run punch the kml file into a SDF.
> Would be easier if it could be read directly into Mapguide though.
> Cheers
