[mapguide-users] Simple OGR FDO question
Traian Stanev traian.stanev at autodesk.com
Fri Mar 12 10:24:00 EST 2010
I recently did a build of the 3.4 FDO OGR provider with dynamic link to GDAL 1.7. It's here:
http://download.osgeo.org/fdo/3.4.1/patches/OGRProvider-3.4.0-gdal17-utf8.zip
If you get a build of GDAL 1.7 DLL with KML support, you should be able to use it with the posted provider.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, March 12, 2010 4:10 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Simple OGR FDO question
Hmm...
Looks like the KML provider hasn't been updated for 2.1/2010 yet (fdo
3.4.x) so you'd either have to recompile or hope SL-King releases an
updated version...
Maybe Haris or Simon has idea of release plans?
On 2010-03-11, Jamo <adam.jamison at portbris.com.au> wrote:
> Kenneth.
> I thought it would be that easy however ... I get the following error when
> testing the connection in maestro
> 2010-03-12T07:00:17> 	3188	MapGuide Maestro v2.0.0.4586	172.16.40.28
> Administrator
>  Error: An exception occurred in FDO component.
>         Connect failed:
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation() line 83 file
> d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpTestFeatureSourceConnection.Execute() line 100 file
> d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\OpTestFeatureSourceConnection.cpp
>   - MgFdoConnectionManager.Open() line 900 file
> d:\Build\Testarossa_Nightly\BUILD_30.1\Ent\OS\Server\src\Common\Manager\FdoConnectionManager.cpp
> The file in question can be found in this google earth network link
> http://www.marinetraffic.com/ais/ge.aspx
> which calls this page http://marinetraffic2.aegean.gr/ais/getkml.aspx
> I have extracted the kml document form the kmz prior to testing in mapguide.
> any thoughts?
> Jason.
> I'm using Mapguide Enterprise 2010 Do I have to recompile the SL.King.KML
> provider to function with my version of FDO? I haven't tried the provider
> yet but I'm not sure on how the FDO versions effect seperate providers built
> for different versions of FDO.
> http://n2.nabble.com/Simple-OGR-FDO-question-tp4714152p4718727.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
