[mapguide-users] mapguide installation problems - libxerces-c.so
Trevor Wekel trevor_wekel at otxsystems.com
Sun Mar 14 14:27:50 EDT 2010
Hi Salih,
I apologize for the delay.  I had to run a full linux build again to see this warning message.  Basically, libxerces-c.so.25 is coming from Fdo and libxerces-c.so.27 is included in the MapGuide Oem tree as part of BerkeleyDB.  Some of the XML parsing utilities used by the Drawing Service also use libxerces-c.so.27 so that is why you see the warning there.
This linker message is a warning and not an error.  GCC should still be generating binaries for you.  Ideally, Fdo and MapGuide should be using the same version of xerces.  As far I know, we have been using different versions of xerces in this manner for at least two releases.  You should be able to ignore the warning.
Regards,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Salih BiLGiN
Sent: March 11, 2010 2:38 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] mapguide installation problems - libxerces-c.so
Hi Trevor,
I tried with FDO 3.4.1. But with the same error output.
/usr/bin/ld: warning: libxerces-c.so.27, needed by /root/MgDev/Server/src/Services/Drawing/.libs/libMgServerDrawingService.so, may conflict with libxerces-c.so.25
Do you have another suggestion?
Regards.
Salih.
2010/3/11 Salih BiLGiN <uzmanium at gmail.com<mailto:uzmanium at gmail.com>>
Hi Trevor,
Thank you for answer. I will trying fdo 3.4.1 .
Regards.
2010/3/11 Trevor Wekel <trevor_wekel at otxsystems.com<mailto:trevor_wekel at otxsystems.com>>
Hi Salih,
You will need to use Fdo 3.4.1 with MapGuide 2.1.  Fdo 3.5.0 should only be used with MapGuide 2.2.  The MapGuide 2.2 beta has not been released yet.
Regards,
Trevor
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>] On Behalf Of Salih BiLGiN
Sent: March 10, 2010 4:26 PM
To: mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
Subject: RE: [mapguide-users] mapguide installation problems - libxerces-c.so
I'm trying to do the installation, I forgot to give information about the system.System information as follows:
Operation System  : Centos 5.4
Fdo = 3.5.0
Mapguide = 2.1
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100314/45d12cb9/attachment.html
