[mapguide-users] Re: who use which viewer API version?
Ivan Miličević
Ivan.Milicevic at supranet.hr
Fri Mar 19 04:56:21 EDT 2010
Hello,
Legend is hidden. Yes, if you remove it there's a problem.
What technology? Grids are filled with jSON (pure AJAX request). Everything is based on lastets EXTjs core (raw EXT, no Geo EXT at all).
Yes, I'm using HTML frame inside panel :)
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Gountanis
Sent: Thursday, March 18, 2010 5:58 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: who use which viewer API version?
Ivan Miličević-3 in your example it looks like ExtJS and the basic viewer map
only. Very cool looking! Mind if I ask what technology you used to
incorporate EXTJS with C#?
Did you just hide the legend or remove it. I found if you remove the legend
frame many things break.
Did you use Ext.Direct for example?
Also, did you look at GEOExt or did you just use the raw ExtJS as is?
Are you using HTML frame for the map viewer within ExtJS panel?
Thanks!
Chris Gountanis
PS Can others elaborate on what worked and what they tried that doesn't?
View this message in context: http://n2.nabble.com/who-use-which-viewer-API-version-tp4736627p4757755.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
