[mapguide-users] (1092688208) Resource was not found:
Library://Samples/Layouts/Sample.WebLayout
kfwebb at bombasticlocution.com
Mon Mar 22 16:11:47 EDT 2010
Greetings!
I just got MapGuide 2.1.0 compiled and going on 64-bit RH -
Linux localhost.localdomain 2.6.23.1-42.fc8 .
I have loaded the Sheboygan,mgp file using the mapadmin tool
http://localhost:8008/mapguide/mapadmin/login.php
which displays the following message in the 'Load Package' utility -
LOAD SUCCEEDED: localhost.localdomain successfully loaded package on
2010-03-22T11:51:11.837659 .
When I load this URL
http://localhost:8008/phpviewersample/ajaxviewersample.php
the stderr from mgserver dumps this
and the Apache error log dumps this
[Mon Mar 22 16:03:35 2010] [warn] [client 127.0.0.1] (104)Connection
reset by peer: mod_fcgid: error reading data from FastCGI server,
referer:
http://localhost:8008/mapviewerphp/ajaxviewer.php?SESSION=eb545550-181b-102d-8000-00e081648629_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout
[Mon Mar 22 16:03:35 2010] [error] [client 127.0.0.1] Premature end of
script headers: mapframe.php, referer:
[Mon Mar 22 16:03:35 2010] [error] mod_fcgid:
process /usr/local/mapguideopensource/webserverextensions/php/bin/php-cgi(11527) exit(communication error), get unexpected signal 11
There are contents in the server/Repositories/Library directory -
[root at localhost Library]# pwd
/usr/local/mapguideopensource/server/Repositories/Library
[root at localhost Library]# ls -al
total 10852
drwxr-xr-x 3 root root 4096 2010-03-22 15:53 .
drwxr-xr-x 6 root root 4096 2010-03-22 10:09 ..
drwxr-xr-x 59 root root 4096 2010-03-22 11:51 DataFiles
-rw-r----- 1 root root 24576 2010-03-22 15:53 __db.001
-rw-r----- 1 root root 1581056 2010-03-22 15:53 __db.002
-rw-r----- 1 root root 41951232 2010-03-22 15:53 __db.003
-rw-r----- 1 root root 12648448 2010-03-22 15:53 __db.004
-rw-r----- 1 root root 557056 2010-03-22 15:53 __db.005
-rw-r----- 1 root root 286720 2010-03-22 15:53 __db.006
-rw-r----- 1 root root 10485760 2010-03-22 15:53 log.0000000001
-rw-r----- 1 root root 1376256 2010-03-22 15:53
MgLibraryResourceContents.dbxml
-rw-r----- 1 root root 98304 2010-03-22 10:09
MgLibraryResourceData.db
-rw-r----- 1 root root 1114112 2010-03-22 15:53
MgLibraryResourceHeaders.dbxml
Any ideas?
I tried using the mapagent tool
http://localhost:8008/mapguide/mapagent/index.html
but the only file in my www/mapagent directory is mapagent.fcgi.
Am I missing something?
KFW
