[mapguide-users] (1092688208) Resource was not found:
Library://Samples/Layouts/Sample.WebLayout
kfwebb at bombasticlocution.com
Mon Mar 22 18:22:22 EDT 2010
The problem seems to be morphing - not quite to the level of "stupid
user" but ...
The ajaxviewersample.php app still reports an "Internal Server Error."
The mgserver Access.log now reports success on Sheboygan.mgp
<2010-03-22T17:46:40> 1125321040 Anonymous CreateSession.1.0.0:0()
Success
<2010-03-22T17:46:41> 1108478288 Ajax Viewer 127.0.0.1 Anonymous
GetResourceContent.1.0.0:2(Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout,) Success
<2010-03-22T17:46:41> 1109530960 Ajax Viewer 127.0.0.1 Anonymous
GetDefaultTileSizeX.1.2.0:0() Success
<2010-03-22T17:46:41> 1110583632 Ajax Viewer 127.0.0.1 Anonymous
GetDefaultTileSizeY.1.2.0:0() Success
<2010-03-22T17:46:41> 1111636304 Ajax Viewer 127.0.0.1 Anonymous
GetResourceContent.1.0.0:2(Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition,) Success
Apache error.log entry remains the same.
[Mon Mar 22 17:46:41 2010] [warn] [client 127.0.0.1] (104)Connection
reset by peer: mod_fcgid: error reading data from FastCGI server,
referer:
http://localhost:8008/mapviewerphp/ajaxviewer.php?SESSION=5277d910-182a-102d-8000-00e081648629_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout
[Mon Mar 22 17:46:41 2010] [error] [client 127.0.0.1] Premature end of
script headers: mapframe.php, referer:
[Mon Mar 22 17:46:42 2010] [error] [client 127.0.0.1] File does not
exist: /usr/local/mapguideopensource/webserverextensions/www/favicon.ico
[Mon Mar 22 17:46:44 2010] [error] [client 127.0.0.1] File does not
[Mon Mar 22 17:46:47 2010] [error] mod_fcgid:
process /usr/local/mapguideopensource/webserverextensions/php/bin/php-cgi(12339) exit(communication error), get unexpected signal 11
Firebug is showing the error occurring on this request
http://localhost:8008/mapviewerphp/mapframe.php?MAPDEFINITION=Library%3A
%2F%2FSamples%2FSheboygan%2FMaps%
2FSheboygan.MapDefinition&TYPE=HTML&SHOWLEGEND=1&SHOWPROP=1&INFOWIDTH=200&LOCALE=en&HLTGT=1&HLTGTNAME=&SHOWSLIDER=1&SESSION=5277d910-182a-102d-8000-00e081648629_en_7F0000010AFC0AFB0AFA
Ideas?
KFW
On Mon, 2010-03-22 at 16:11 -0400, kfwebb at bombasticlocution.com wrote:
> Greetings!
> I just got MapGuide 2.1.0 compiled and going on 64-bit RH -
> Linux localhost.localdomain 2.6.23.1-42.fc8 .
> I have loaded the Sheboygan,mgp file using the mapadmin tool
> http://localhost:8008/mapguide/mapadmin/login.php
> which displays the following message in the 'Load Package' utility -
> LOAD SUCCEEDED: localhost.localdomain successfully loaded package on
> 2010-03-22T11:51:11.837659 .
> When I load this URL
> http://localhost:8008/phpviewersample/ajaxviewersample.php
> the stderr from mgserver dumps this
> and the Apache error log dumps this
> [Mon Mar 22 16:03:35 2010] [warn] [client 127.0.0.1] (104)Connection
> referer:
> http://localhost:8008/mapviewerphp/ajaxviewer.php?SESSION=eb545550-181b-102d-8000-00e081648629_en_7F0000010AFC0AFB0AFA&WEBLAYOUT=Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout
> [Mon Mar 22 16:03:35 2010] [error] [client 127.0.0.1] Premature end of
> [Mon Mar 22 16:03:35 2010] [error] mod_fcgid:
> process /usr/local/mapguideopensource/webserverextensions/php/bin/php-cgi(11527) exit(communication error), get unexpected signal 11
> There are contents in the server/Repositories/Library directory -
> [root at localhost Library]# pwd
> /usr/local/mapguideopensource/server/Repositories/Library
> [root at localhost Library]# ls -al
> total 10852
> drwxr-xr-x 3 root root 4096 2010-03-22 15:53 .
> drwxr-xr-x 6 root root 4096 2010-03-22 10:09 ..
> drwxr-xr-x 59 root root 4096 2010-03-22 11:51 DataFiles
> -rw-r----- 1 root root 24576 2010-03-22 15:53 __db.001
> -rw-r----- 1 root root 1581056 2010-03-22 15:53 __db.002
> -rw-r----- 1 root root 41951232 2010-03-22 15:53 __db.003
> -rw-r----- 1 root root 12648448 2010-03-22 15:53 __db.004
> -rw-r----- 1 root root 557056 2010-03-22 15:53 __db.005
> -rw-r----- 1 root root 286720 2010-03-22 15:53 __db.006
> -rw-r----- 1 root root 10485760 2010-03-22 15:53 log.0000000001
> -rw-r----- 1 root root 1376256 2010-03-22 15:53
> MgLibraryResourceContents.dbxml
> -rw-r----- 1 root root 98304 2010-03-22 10:09
> MgLibraryResourceData.db
> -rw-r----- 1 root root 1114112 2010-03-22 15:53
> MgLibraryResourceHeaders.dbxml
> Any ideas?
> I tried using the mapagent tool
> http://localhost:8008/mapguide/mapagent/index.html
> but the only file in my www/mapagent directory is mapagent.fcgi.
> Am I missing something?
> KFW
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
